garrickmosko
Nov 13, 2019Follower
Costco Orbi
Costco has a few Orbis. Besides the range is the speed going to be the same?
Nov 13, 2019Guru - Experienced User
There are some differences in the wireless backhaul speeds between the models:
michaelkenward
It might be worth searching for "Costco" around here.
Some people have found that they owned customised Orbi devices that they could not control or update. These came from an ISP, but I would not want to risk being stranded.
- FURRYe38Nov 13, 2019Guru - Experienced User
Most of the routers sold at Costco are just retail units and are controllable and upgradable. The ones the do some from ISPs though, those are some to review first before you consider buying from them. Espeically Verizon.
