Fpommett
Apr 16, 2020Aspirant
Cox Cable Compatibility
I am looking to upgrade the router-modem for my Cox Cable "Ultimate" service. Cox doesn't list the Orbi AC3000 as compatible with their service. I think that's because it's too new. Please offer a...
- AnonymousApr 17, 2020
Fpommett wrote:Thanks for your reply. What model modem do you have with your Orbi router?
Frank
https://www.arris.com/surfboard/products/cable-modems/sb6183/
Apr 16, 2020Guru - Experienced User
Reason why the RBK is not on there list or any list is that the RBK doesn't include a cable modem. It's just a router and wifi system.
Check there list again for what they support in "Cable Modem". NG has CM 1000, 1100 and 1200 modems that are just modesm only and will work with your RBK Orbi system.
