Fpommett
Apr 16, 2020Aspirant
Cox Cable Compatibility
I am looking to upgrade the router-modem for my Cox Cable "Ultimate" service. Cox doesn't list the Orbi AC3000 as compatible with their service. I think that's because it's too new. Please offer a...
- Retired_MemberApr 17, 2020
Fpommett wrote:Thanks for your reply. What model modem do you have with your Orbi router?
Frank
https://www.arris.com/surfboard/products/cable-modems/sb6183/
Retired_Member
Apr 16, 2020
Fpommett wrote:I am looking to upgrade the router-modem for my Cox Cable "Ultimate" service. Cox doesn't list the Orbi AC3000 as compatible with their service. I think that's because it's too new. Please offer advice.
I have cox and I recommend NOT using a router-modem combo. I can't make out what you have now.
my cox system is modem to orbi plus 2 sats. That's it.
cox is one of the few isps that don't require you use their gear. The orbi is not new.
keep it simple.
Fpommett
Apr 17, 2020Aspirant
Frank
