tokyotony
Mar 22, 2021Aspirant
Cox Gigablast/Orbi ethernet connection slow compared to desktop connection
I just upgraded to Cox Gigablast which can give me roughly 900 down and 35 up. Our desktop PC is connected to the Cox router via ethernet and we are getting roughly 600 down. BUT, when I test the sp...
Mar 22, 2021Guru - Experienced User
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- tokyotonyMar 22, 2021Aspirant
1. Bridge for Cox. I would prefer not to do this since my son connects his gaming machine directly to it.
2. I'll have to look moree into that.
3. I tried AP mode and the speed hasn't changed.
thanks!
