tokyotony
Mar 22, 2021Aspirant
Cox Gigablast/Orbi ethernet connection slow compared to desktop connection
I just upgraded to Cox Gigablast which can give me roughly 900 down and 35 up. Our desktop PC is connected to the Cox router via ethernet and we are getting roughly 600 down. BUT, when I test the sp...
Mar 22, 2021Guru - Experienced User
What do you get with Ooklas speed test app installed on the PC using the wired connection to the RBR?
What FW version are you using?
Sounds like your modem maybe slowing the connection down between the modem and RBR maybe...
tokyotony
Something seems to be going on with my WAN port. According to the stats, it is only 100M.
(Attaching screeen shot since I don't know why the embed doesn't work properly.)
