KaneB
Oct 31, 2018Aspirant
Creating a secure Guest network with Orbi
I have a guest network setup in my orbi and as I understand, it seems to be able to see other devices in the network and a guest device can also potentially take all the bandwidth since I cannot thro...
- Nov 01, 2018For the benefit of others, I can confirm this works as a setup.
I bought a cheap GL inet travel router from Amazon which is about £16. It is fully featured and has the ability to limit bandwidth using its QOS features.
KaneB
Thank you for your response.
Does Netgear have a router with bandwidth control on a hardware level? So instead of controlling it on a software level which they could potentially bypass. The actual hardware is only limited to a total of say 35mbps traffic?
Oct 31, 2018Guru - Experienced User
Not that I know of.
