Odymann's avatar
Odymann
Guide
Feb 28, 2018
Cujo and Orbi
Hi,
I would like to know want is the best way to have all my IP address to be the same on my network with Cujo installed. I tried carious setting and turn on/off the DHCP and Cujo like create a separate IP. It says "Device network overlaps the router-cujo network." What does it mean? Thanks.
1 Reply
  • FURRYe38's avatar
    Cujo is a fireall appliance device. Seems to have it's own DHCP server. With the Orbi router, it has a DHCP server as well.
    You either need to bridge the Cujo appliance and disable his DHCP server or use the Orbi router in AP mode and connect it to the Cujo appliance and let it be your main DHCP server.
    Odymannwrote:
    Hi,
