Sabbsol
May 05, 2021Tutor
Current list of Ethernet switches that work with Orbi RBR50
Hi,
So I discovered that my TPlink TL-SG116 switch is causing my wired connection problems (Green Ethernet features), and I want to swap it for a switch that works well with my Orbi. Previous recommendations in these forums seem to be older models and the newer versions have Green Ethernet that can't be switched off.
Can anyone help with a list of a few current model switches that definitely work (or let you turn off Green Ethernet). I don't need management or VLAN's or anything. In my location I can't just try them and return them, so I need to get one that definitly works with Orbi.
thanks
What I've used:
Netgear GS908E
Netgear GS716v2
TP-link TL-SG105
And a couple of other tp-link 8 port switches, I'm not currently using (loaned out because I upgraded)
I haven't had one I couldn't get working but most are pretty simple unmanaged switches.
But I have read of people having issues with greens switches. I know at least one of the tp-link's i've used was green and worked.
Seems to be a bit hit/miss.
- SabbsolTutor
Thanks, my TP-Link also works, but sometimes stops mysteriously on different ports, and when it happens on the router port the satellites satellite users and wired users are disconnected. It happens about every few days. I found a workaround - just switch the cables around (so the switch sees different mac addresses) and restart the switch - but again it is only a short term fix.
I really need one that will work reliably - preferably 16 gigabit ports, could get by with 8
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
