bashfulrobot
Jun 26, 2019Tutor
Custom DNS with ISP DHCP
Hi there, I would like to use a custom DNS server (not my ISP's DNS), but they need DHCP for me to connect. It seems like i cannot change this setting on the orbi unless I use a static with my I...
CrimpOn
Jun 26, 2019Guru - Experienced User
On the web interface, Advanced Tab->Internet Setup the choices for DHCP and DNS servers are separate.
- michaelkenwardJun 28, 2019Guru - Experienced User
Yes, but on the RBS50Y?
That's a satellite.
Try tweaking the unnamed router.
- bashfulrobotJun 28, 2019Tutor
It is actually the RBR50. Sorry. But it stil will not let me change it.
- FURRYe38Jun 29, 2019Guru - Experienced User
What mode is your RBR50 running in? Router mode should allow you to change DNS to any custom DNS.
Using DHCP or PPPoE for your ISP services?
bashfulrobot wrote:It is actually the RBR50. Sorry. But it stil will not let me change it.
