bashfulrobot
Jun 26, 2019Tutor
Custom DNS with ISP DHCP
Hi there, I would like to use a custom DNS server (not my ISP's DNS), but they need DHCP for me to connect. It seems like i cannot change this setting on the orbi unless I use a static with my I...
michaelkenward
Jun 28, 2019Guru - Experienced User
Yes, but on the RBS50Y?
That's a satellite.
Try tweaking the unnamed router.
bashfulrobot
Jun 28, 2019Tutor
It is actually the RBR50. Sorry. But it stil will not let me change it.
- FURRYe38Jun 29, 2019Guru - Experienced User
What mode is your RBR50 running in? Router mode should allow you to change DNS to any custom DNS.
Using DHCP or PPPoE for your ISP services?
bashfulrobot wrote:It is actually the RBR50. Sorry. But it stil will not let me change it.
- bashfulrobotJul 02, 2019Tutor
It is in the router mode (not the AP mode). TEH only way I cn change the DNS is to move my internet connection to a "static" ip vs the DHCP my ISP requires.... it is so odd.
- michaelkenwardJul 02, 2019Guru - Experienced User
You never did answer the question from FURRYe38 as to the modem in front of this thing. It could be important.
