bashfulrobot
Jun 27, 2019Tutor
Custom DNS with ISP DHCP
Hi there, I would like to use a custom DNS server (not my ISP's DNS), but they need DHCP for me to connect. It seems like i cannot change this setting on the orbi unless I use a static with my I...
bashfulrobot
Jul 02, 2019Tutor
It is in the router mode (not the AP mode). TEH only way I cn change the DNS is to move my internet connection to a "static" ip vs the DHCP my ISP requires.... it is so odd.
michaelkenward
Jul 02, 2019Guru - Experienced User
You never did answer the question from FURRYe38 as to the modem in front of this thing. It could be important.
