bashfulrobot
Jun 26, 2019Tutor
Custom DNS with ISP DHCP
Hi there, I would like to use a custom DNS server (not my ISP's DNS), but they need DHCP for me to connect. It seems like i cannot change this setting on the orbi unless I use a static with my I...
Jul 04, 2019Guru - Experienced User
What happens if you disconnect the WAN port from the ISP modem and try to configure the DNS?
Might try a factory reset on the RBR, setup from scratch, this time, skip the setup wizard and setup the RBR manually while the RBR is not connected to the ISP modem. Go in and see if you can set manual DNS first.
bashfulrobot
Jul 04, 2019Tutor
I might go that way, but that seems to be the answer for every issue I post on here. I have reloaded and reconfigured this damn thing so many times. When this thing works, it is awesome, but it is flakey as heck. Settings changing on their own, (ie block new clients by default, vs not), Stuff like this. Circle periodically disabling and so on. Not overly confident in this thing.
