bashfulrobot
Jun 27, 2019Tutor
Custom DNS with ISP DHCP
Hi there, I would like to use a custom DNS server (not my ISP's DNS), but they need DHCP for me to connect. It seems like i cannot change this setting on the orbi unless I use a static with my I...
Jul 07, 2019Guru - Experienced User
Might see if you can barrow a laptop if you have a friend or neighbor with one. Even a Mac.
Try another Orbi system to see if the problem still happens on a different system.
bashfulrobot
Jul 08, 2019Tutor
My Wife had her work computer home — the same issue in multiple browsers.
I guess I am stuck at restoring. This unit is becoming so insanely frustrating. It feels like I need to flash this thing every damn time there is a problem (which is often).
- FURRYe38Jul 08, 2019Guru - Experienced User
Should have too. I would factory reset the RBR, manually load FW. Factory reset and setup from scratch. I would use either Windows or Mac native if possibe. Setup the custome DNS after you get thru the setup wizard. Once you get that configured, save off a backup configuration to file for safe keeping.
- bashfulrobotJul 09, 2019Tutorthank you for the feedback. I'll give that a go. But this thing is about one step away from hitting the trash can. I'm absolutely sick of having to reload this thing all the time.
- FURRYe38Jul 09, 2019Guru - Experienced User
Let us know how it turns out. I agree, shouldn't have to keep re-loading or resetting it. When you get it all set again fully, do a backup configuration to file for safe keeping.
