SDuane
Jun 07, 2020Follower
Cutting the Cord using AT& T internet
I currently have ATT U-Verse using their equipment and attaching wirelessly to three addional televisions. I also have the other usual devices like cell phones, ipad and several computers all using ...
- Jun 08, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATYou can connect any external router to your modem, however you'll need to configure the modem and router for one of the following options....
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Jun 08, 2020Guru - Experienced User
