bowler900
Jul 28, 2017Tutor
D6200 and Orbi
I have had a D6200 ADSL/ADSL2 WiFi Router for some years, I am in the process of purchasing Orbi as I am unable to cover the house just with the router. 2 Questions: Is orbi compatible with the D620...
bowler900
Jul 28, 2017Tutor
I need it in router mode as I have run out of MAC address slots on the D6200 which I use to control access.
I assume Orbi is able to handle more than the D6200 can.
samulel
Jul 30, 2017Guide
Yes, Technically you can connect 253 devices since the DHCP ip range from xx.xx.xx.(0-254), and for sure it is more powerfull than D6200.
- bowlerJul 30, 2017Aspirant
Typically the Wireless Card Access List on the D6200 holds 64 entries which is more than my previous Netgear router I am hoping that Orbi can accomodate more as when my grandchildren appear with numberous devices I dont have to keep editing the list or leaving the WiFi open for them.
How many items can Orbi handle in its Wireless Card Access List?
- samulelJul 30, 2017Guide
D6200 each band support 32 clients so totally 64 clients and Orbi is triband on sinlge SSID so it will support 96 wireless Clients .ca
D6200 each band support 32 clients so totally 64 clients and Orbi is triband on sinlge SSID so it will support 96 wireless Clients. And each unit coverage is 2000 Sqft so that is good Choice.
