shsteve
Feb 27, 2020Follower
D7000 and Orbi installing apps on Windows 10
Hi I have D7000 Nighthawk and was using the Genie App on my Windows 7 laptop and android phone. I have upgraded to Windows 10 but when I try to install (from Google Play) Genie or Nighthawk - WIFI...
michaelkenward
Feb 28, 2020Guru - Experienced User
shsteve wrote:
And once that is running I will be adding an Obi to the mix, but if I install the Orbi app, how will I access the Nighthawk to set up the parameters.
You can use the Orbi app to access an Orbi in AP mode.
On a PC you can get in by working out the IP address if the Orbi and attacking it from that direction. I find it helps to fix the IP address on the AP so that I can always find it.
Does the D7000 work with the Nighthawk app? As far as I can see it is still in the hands of the Netgear Genie app. (Some people think that is a good thing.)
At takes a firmware change to move a device from Netgear app to Nighthawk app. As usual, modem/routers are at the back of the queue on these things.
shsteve wrote:
However I can't get them to installed on my Laptop as it is not an option in the Google Shop dropdown box.
If you want the desktop genie for Windows start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
