SpikeB's avatar
SpikeB
Initiate
Oct 07, 2018
Daikin Wifi
I am trying to connect a Daikin WLAN adapter through my Orbi mesh but for some reason my Orbi is not being found. Seeing as all of my neighbour's WiFi routers show up, I guess the error is somewhere i...
  • SpikeB's avatar
    SpikeB
    Oct 14, 2018
    Brilliant, thank you very much, got there in the end.
    I'd already tried using Channel 11 but with no joy so I thought it was something else. I don't know if that's peculiar to my set up though because I moved out to 6 and it's working perfectly.
    Thanks again.
