alchemista
Oct 06, 2021Tutor
Daily Internet & Wifi disconnects: RBR40, RBS40, and RBW30
RBR40: FW V2.7.3.22 + 3 satellites: 1x RBS40 - FW V2.7.3.22 2x RBW30 - FW V2.6.2.6 Symptoms: Multiple times daily - some days worse than others: 1) Wifi will stay connected but Internet co...
Oct 06, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Use a whois look up on this IP addresses to see where they come from.
