SRNIJMU
May 26, 2020Aspirant
Daily Reboot Required
My Orbi was working fine for a year until about two weeks ago and now requires daily reboots. The network connection drops. After rebooting, everything is fine for about a day. Some days, two reboots...
SRNIJMU
Thank you. Will answer to the best of my ability below the questions:
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
>Comcast XB6 xFi Advanced Gateway Modem TG3482G (ARRIS)
> Distance is less than 30 feet. It's a total loss. Computers connected directs to the router by less than 10 feet lose signal line-of sight also.
Any Wifi Neighbors near by? If so, how many?>Channels are Auto. Maybe pick up one wifi neighbor weakly nearby. With your suggestions here and below, is there an order in which you recommend trying them? Why would this be required after a year of good function?
>See about about question regarding order of fix attempts.
>No - would this help?
May 26, 2020Guru - Experienced User
What mode is the Arris modem working in? Bridge mode is recommended since this model has a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
RBS should be 30 feet to start or farther. Any closer can cause problems.
Try any of the suggested channels. Due to conditions, neighbor changes and new neighbors may have install there own wifi, this could cause interferences over the years.
"See about about question regarding order of fix attempts." Huh?
I would factory reset first then use the suggestions after you walk thru the setup wizard...pending on modem mode operation confirmation first.
- SRNIJMUMay 26, 2020Aspirant
Thank you so very much for your prompt responses. The modem is in bridge mode. Sorry for the confusion, what I meant about "order of the fixes" is that you suggested a few things and I wanted to know which you recommended I try first. I see you have answered that question below. Your help is much appreciated.
FURRYe38 wrote:What mode is the Arris modem working in? Bridge mode is recommended since this model has a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopRBS should be 30 feet to start or farther. Any closer can cause problems.
- FURRYe38May 26, 2020Guru - Experienced User
:smileywink:
