stevefxp
Jul 17, 2019Apprentice
Daisy Chain - Checked or Not Checked
I am running with a RBR50 and RBW30. The RBR50 satellite is wired ethernet connected to the router. Since the RBW30 does not have an ethernet port it is connected via wireless backhaul. If I have Ena...
Jul 18, 2019Guru - Experienced User
If you only have 1 RBW then Daisy Chain can be disabled as this feature needs two or more satellites to be of benefit.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
stevefxp wrote:I am running with a RBR50 and RBW30. The RBR50 satellite is wired ethernet connected to the router. Since the RBW30 does not have an ethernet port it is connected via wireless backhaul. If I have Enable Daisy Chain Topology checked then the backhaul status on both satellites shows as Good. If I have Enable Daisy Chain Topology unchecked then the backhaul status on the RBW30 shows as Poor. Does this mean it cannot establish a clean backhaul to the router, as I am assuming the RBW30 is connecting via wireless backhaul to the other satellite when Enable Daisy Chain Topology is checked.
