dbelle
Apr 09, 2020Follower
Daisy Chain 2 Orbi
Is it possible to hook up an orbi on 1st floor as a router with satellites, then run a cable and daisy chain a second orbi to my 2nd floor and have satellites hooked up? I have two large floors all seperated by concrete and would like to get coverage throughout.
1 Reply
The two systems would not be MESHd together. You could use the 2nd RBR in AP mode though it would still be a separate SSID name.
RBRs can not be used as satellites.
You can do this with RBSs:
