MichelleGi
Oct 12, 2020Aspirant
Daisy Chain Connection issues in RBR20
Help - I don't speak geek. I purchased an orbi rbr20 a while ago and 2 satellites. I had to use customer support to force it to do what I needed it to do. I need a daisy chain that goes from router ...
MichelleGi
This is very helpful and clearly presented, except that it didn't work. It gave me the same star configuration that I started with. I think the next thing to try would be to delete the second satellite and redo it. Would I need to reboot satellite 1 again, or leave it be and just deal with satellite 2?
Mstrbig
Oct 13, 2020Master
MichelleGi wrote:This is very helpful and clearly presented, except that it didn't work. It gave me the same star configuration that I started with. I think the next thing to try would be to delete the second satellite and redo it. Would I need to reboot satellite 1 again, or leave it be and just deal with satellite 2?
The one thing
One thing is, if the satellite gets a better connection to the router over the other satellite, it will take it.
You could try factory resetting both satellites and re-syncing them one at a time.
- MichelleGiOct 13, 2020Aspirant
Thank you. I will try that. When it is in the star configuration my satellite #2 gets about 50mps down compared to 300mps when going direct. So I am at a loss as to figure out why it thinks that is better.
- NGC_UserNov 20, 2020Initiate
What was the result of your re-configuration? Were you able to get it working in Daisy Chain mode?
- FURRYe38Nov 20, 2020Guru - Experienced User
Any progress on this?
MichelleGi wrote:Thank you. I will try that. When it is in the star configuration my satellite #2 gets about 50mps down compared to 300mps when going direct. So I am at a loss as to figure out why it thinks that is better.
