MichelleGi
Oct 12, 2020Aspirant
Daisy Chain Connection issues in RBR20
Help - I don't speak geek. I purchased an orbi rbr20 a while ago and 2 satellites. I had to use customer support to force it to do what I needed it to do. I need a daisy chain that goes from router ...
MichelleGi
Oct 13, 2020Aspirant
Thank you. I will try that. When it is in the star configuration my satellite #2 gets about 50mps down compared to 300mps when going direct. So I am at a loss as to figure out why it thinks that is better.
NGC_User
Nov 20, 2020Initiate
What was the result of your re-configuration? Were you able to get it working in Daisy Chain mode?
