mallen943
Oct 20, 2019Follower
Daisy Chain Coverage
I currently have a Orbi RBK-50 kit. I am contemplating buying a RBS50Y extender to daisy chain off my indoor satellite to provide outdoor connectivity for a Ring Spotlight camera. The point of loca...
CrimpOn
Oct 20, 2019Guru - Experienced User
mallen943 wrote:My question is .... the approximate distance I would be able to locate the camera from the RBS50Y extender.
The Ring Spotlight Camera specs show connectivity as "802.11 b/g/n Wi-Fi connection @ 2.4GHz"
https://shop.ring.com/products/spotlight-cam-battery
I have found estimates for 2.4G for over 150ft. in open space.
https://www.lifewire.com/range-of-typical-wifi-network-816564
The Ring specs say it needs an upload speed of 2MB/sec, which is not a lot.
So, if the Ring camera has a clear line of sight to the RBS50Y, you are "good to go."
