MarkLOrbi
Nov 04, 2018Guide
Daisy chain mode not working
Bought an RBS50Y outdoor satellite to add to the RBK50 router and 3 RBS50 indoor satellites I already have. The outdoor satellite won't go into daisy chain mode, and the router status page shows the ...
- Nov 07, 2018
MarkLOrbi wrote:
st_shaw wrote:
Orbi is not the right product for your application. Orbi is designed to provide blanket WiFi over a contiguous area, not to provide reliable data links between distant points. What you really need is pairs of wireless point-point links between buildings then a wired access point inside each building for client WiFi. Point-to-point links have directional antennas and are designed to maintain good throughput and a reliable connection. You could still use Orbi inside the main building where the Internet drop is. In theory, since you alread have them, you could wire a satellite to the point-to-point device at each building to provide client WiFi in that building, but I wouldn't recommend that if you didn't already have the sats.
I'm not trying to provide wifi inside the buildings, they are occupied by animals and tractors. The purpose of the wifi is to provide coverage for the wireless security cameras that are on the outside of and between the buildings. So it is a contiguous area that's covered by security cameras. The only place there are people are in the house where the router is.
Thanks. Slightly different application, but the technical limitations are still the same, so Orbi is still a poor fit. Orbi doesn't have directional antennas, so the sats and router cannot achieve a good stable link over the distances you're operating. You would still be better of with PTP links and an AP on each building close to the casmeras.
Good luck though.
Nov 04, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. If your wanting actual daisy chaing between your satelllites, then uncheck mark Daisy Chain in the UI.
MarkLOrbi
Nov 04, 2018Guide
I've included the info you asked but, as I mentioned, I've had daisy chain working for a year with my existing satellites. So it would seem likely the issue is related to the new outdoor satellite I've just purchased and added to the exisiting setup.
Uverse Arris BGW210
It's not just the home, it's a farm. Router and one satellite are at opposite ends of the home which is 2000sf, two satellites are in a building which is 100' from the house and about 175' long, and the new outdoor sat is in a work shed about 50' from the house.
I've been running with some satellites 150' apart for a year, I moved things around to find spots that avoided trees, siding, etc, to locate spots where things worked. One of the satellites is only about 30' from the router because the house construction is in the way. The new outdoor satellite is about 50' from one of the existing indoor satellites, and about 80' from the router.
>> What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz >> and any unused channel on 5Ghz.
Yes, Auto
I'm running v210 and daisy chaining has been working with one of my satellites for a year, so it can't be a problem with the setting.
