MarkLOrbi
Nov 04, 2018Guide
Daisy chain mode not working
Bought an RBS50Y outdoor satellite to add to the RBK50 router and 3 RBS50 indoor satellites I already have. The outdoor satellite won't go into daisy chain mode, and the router status page shows the ...
- Nov 07, 2018
MarkLOrbi wrote:
st_shaw wrote:
Orbi is not the right product for your application. Orbi is designed to provide blanket WiFi over a contiguous area, not to provide reliable data links between distant points. What you really need is pairs of wireless point-point links between buildings then a wired access point inside each building for client WiFi. Point-to-point links have directional antennas and are designed to maintain good throughput and a reliable connection. You could still use Orbi inside the main building where the Internet drop is. In theory, since you alread have them, you could wire a satellite to the point-to-point device at each building to provide client WiFi in that building, but I wouldn't recommend that if you didn't already have the sats.
I'm not trying to provide wifi inside the buildings, they are occupied by animals and tractors. The purpose of the wifi is to provide coverage for the wireless security cameras that are on the outside of and between the buildings. So it is a contiguous area that's covered by security cameras. The only place there are people are in the house where the router is.
Thanks. Slightly different application, but the technical limitations are still the same, so Orbi is still a poor fit. Orbi doesn't have directional antennas, so the sats and router cannot achieve a good stable link over the distances you're operating. You would still be better of with PTP links and an AP on each building close to the casmeras.
Good luck though.
Nov 04, 2018Guru - Experienced User
What is the current Daisy Chain setting on the ORbi router? Checked or Unchecked?
What mode is your ISP modem running in? Router or PassThru or bridge mode? Just curious here.
MarkLOrbi
Nov 04, 2018Guide
The box is checked that says "Enable Daisy-Chain Topology"
My modem is in router mode, I have the orbi set to AP mode.
- FURRYe38Nov 04, 2018Guru - Experienced User
Ok, lets try Un-Checking Daisy Chain on the Routers UI. Save settings and apply. Then try to connect the RBSY or power cycle the RBSY to see if it connects to a satellite instead of the Router base.
- MarkLOrbiNov 05, 2018Guide
Tell me more about your thinking on this. I already have 2 satellites that are working in daisy chain mode. If the functionality of the checkbox were backwards, why would these two satellites be working in daisy chain mode.
- FURRYe38Nov 05, 2018Guru - Experienced User
There maybe a difference in behavior between the RBS and the RBSY unit. This would be just a quick test to see what happens with changing the behavior of Daisy Chain. You can set it back.
There also maybe a problem with the RBSY as well. Something you should contact NG support about.
