Hanseman
Nov 29, 2019Tutor
Daisy-chain not working as expected
Hi there, I have tried the power-cycling trick as explained here but no success. https://community.netgear.com/t5/Orbi/ORBI-RBR20-won-t-daisy-chain-wirelessly/m-p/1790493#M68733 My 2 satellites...
Dec 04, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- HansemanDec 05, 2019Tutor
The house is about 1 800 sqm but it is quite long.
I would guess the range between each unit is a bit over 30 feet.
The strange thing is that they are in a line but last satellite prefer talking to the router, anyhow.
Backhaul status says Good on both satellites.
Telnet info gives:
"mac address": "28:80:88:F9:BA:6B",
"ip address": "192.168.1.16",
"module name": "RBS50",
"serial number": "5LT2945C0646C",
"signal strength": "-51",
"backhaul status": "2",
"device name": "Orbi Satellite-1",
"current version": "V2.3.5.30"
"mac address": "38:94:ED:0C:78:6C",
"ip address": "192.168.1.15",
"serial number": "5PV1945X06042",
"signal strength": "-71",
"device name": "Orbi Satellite-2",
"current version": "V2.3.5.30"- FURRYe38Dec 05, 2019Guru - Experienced User
What happens if you swap the RBS around?
Has a factory reset been performed on the RBSs and re-synced with Daisy Chain enabled?
Are you using the singal strength to determine how the last RBS is connecting to the RBR or RBS?
I have made factory resets several time.
Not swapped satellites, though. Will make a test.
