tgaertne
Mar 29, 2020Tutor
Daisy chain order
How does Orbi decide to daisy chain vs star network? I have my satellites set up in a way I wanted them to daisy chain. When I first set them up, they worked that way and now for some reason both sat...
- Mar 29, 2020
Under Advanced Tab/Advanced Settings/Wireless Settings
Try putting the remote RBS out at a farther distance to see if it will connect to the 2nd RBS.
Mar 29, 2020Guru - Experienced User
Daisy Chain is enabled on the RBR?
Try a reboot of the RBR only while leaving the RBS on.
- tgaertneMar 29, 2020Tutor3000 square feet. I am within 30 from one to the next. Where do I find spot to enable daisy chain?
- FURRYe38Mar 29, 2020Guru - Experienced User
- tgaertneMar 29, 2020TutorThat worked! Moving it a bit further. So next question is now none of the devices I wanted to have connect to the furthest daisy chained satellite are connecting to it. They are going to the one before it in the daisy chain. Any tips there? Thank you!!!
- tgaertneMar 29, 2020TutorOk. I found setting and it is enabled. I also tried to reboot. Still won’t daisy chain
