tgaertne
Mar 29, 2020Tutor
Daisy chain order
How does Orbi decide to daisy chain vs star network? I have my satellites set up in a way I wanted them to daisy chain. When I first set them up, they worked that way and now for some reason both sat...
- Mar 29, 2020
Under Advanced Tab/Advanced Settings/Wireless Settings
Try putting the remote RBS out at a farther distance to see if it will connect to the 2nd RBS.
Mar 29, 2020Guru - Experienced User
Daisy Chain is enabled on the RBR?
Try a reboot of the RBR only while leaving the RBS on.
tgaertne
Mar 29, 2020Tutor
Ok. I found setting and it is enabled. I also tried to reboot. Still won’t daisy chain
