wifiblues
Apr 08, 2021Luminary
daisy chain RBR40
hi we live in NYC - neighbors to the left, right, below, and above - all with wifi. in our space, we use a RBR40, two RBS20, and an outdoor Orbi 50. our squarefootage is over 2000 plus outdoor roo...
vajim
Apr 08, 2021Master
have you checked your network via pc login?
- wifibluesApr 08, 2021Luminary
hi vajim,
i have checked by logging into the admin online - at first it shows poor then refreshes to good. Does the mapping on the app show illustrate the daisy chain?
thanks...wifiblues
- vajimApr 08, 2021Master
wifiblues wrote:hi vajim,
thanks...wifiblues
I'm not sure. for more help with the app you may want to post your questions here:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
thanks - i will post the app question there - i do have another question that i've been thinking about.
here is the example - let's say i have a mobile device and i move from one area to another - like going up to the roof from indoors - should the wifi connection on the device move from one satellite to another? is that what daisy chain is about? if it is not daisy chain, then is there a setting that allows for that?
thanks,
wifiblues
maybe this will help:
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
