kmulani's avatar
kmulani
Initiate
Jun 07, 2020
Daisy Chain Vs Star Topology - Performance
I previously had a Star Chain Topolgy but ever since I moved the router, the network has switched to a Daisy Chain Topolgy. My question is if this is going to impact the performance in any way as my ...
  • kmulani's avatar
    kmulani
    Jun 09, 2020
    Thanks for the reply. I did detect a slight difference when playing You Tube. Nonetheless I wasnt too comfortable about having one satellite dependent on the other so I moved the router back to its original position and in no time, the network switched to a star topology. Thanks once again
