The111
Jan 17, 2022Aspirant
Daisy-chained RBS750 always goes to "poor" backhaul status if "Connected Orbi" briefly loses power
I could not find my model in the dropdown selector. I have a RBR750 (let's call this R) with 4x satellites (RBS750) (let's call them A, B, C, D). Satellites A, B, and C connect directly to R. But D c...
Jan 17, 2022Guru - Experienced User
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
- The111Jan 17, 2022Aspirant
Thanks, I've copied my question to that other forum you mentioned. Sorry for the misplacement.
Regarding distance between devices, clearly all my devices are placed in an acceptable range since everything functions fine if they all power on at the same time. The issue is that one device briefly losing power can bork part of the network semi-permanently, and the system is aware of that issue but does not attempt to fix it. I don't think changing distances would do anything about that (nor can I change distances).
- FURRYe38Jan 18, 2022Guru - Experienced User
Please post distanced between the current setup in the other forum.
Thanks.
