Philip_Timms
Jun 14, 2020Aspirant
Daisy chaining a 2nd satellite
Models as above - plus one RBS50 satellite in the house. I am wanting to daisy chain the satellite in the house to the satellite in the garden. Router firmware V2.5.1.16 House satellite V2.5.1.1...
Jun 14, 2020Guru - Experienced User
I see that FW you have on the RBSY is for Orbi Pro. Possible that this version of FW may not work with Orbi Home version. You may want to load 2.3.5.32 (Orbi Mode for Orbi)
Ensure Daisy Chain is enabled on the RBR.
Philip_Timms
Thanks - I have gone back to the firmware version you have suggested - but no change!
- FURRYe38Jun 14, 2020Guru - Experienced User
What happens if you turn down the power output on the RBRs radios from 100% to say 50%? Under Advanced Tab/Advanced Settings/Wireless Settings
You may need to move the RBSY farther out from the RBR...
- Philip_TimmsJun 15, 2020Aspirant
thanks - I'm afraid reducing the power made no difference. I will give it one more go further away though.
It's now down the bottom of the garden, still trying to connect with the router rather than the other satellite.
I have attached the screen I get from logging directly into the garden satellite
- FURRYe38Jun 15, 2020Guru - Experienced User
Sounds like you have a bad RBSY or a RBS that the RBSY can't connect to thus the RBSY wants to connect to the RBR.
I would make contact with NG support about this.
