Philip_Timms
Jun 14, 2020Aspirant
Daisy chaining a 2nd satellite
Models as above - plus one RBS50 satellite in the house. I am wanting to daisy chain the satellite in the house to the satellite in the garden. Router firmware V2.5.1.16 House satellite V2.5.1.1...
Philip_Timms
Thanks - I have gone back to the firmware version you have suggested - but no change!
Jun 14, 2020Guru - Experienced User
What happens if you turn down the power output on the RBRs radios from 100% to say 50%? Under Advanced Tab/Advanced Settings/Wireless Settings
You may need to move the RBSY farther out from the RBR...
- Philip_TimmsJun 15, 2020Aspirant
thanks - I'm afraid reducing the power made no difference. I will give it one more go further away though.
It's now down the bottom of the garden, still trying to connect with the router rather than the other satellite.
I have attached the screen I get from logging directly into the garden satellite
- FURRYe38Jun 15, 2020Guru - Experienced User
Sounds like you have a bad RBSY or a RBS that the RBSY can't connect to thus the RBSY wants to connect to the RBR.
I would make contact with NG support about this.
