mabwriter
Apr 20, 2020Aspirant
Daisy Chaining Feature
I plan on incorporating ethernet backhaul with my Orbi Satellites through Star Topology (linking the router directly to the satellites). If I do this, do I need to turn off Daisy Chaining in the sett...
Apr 20, 2020Guru - Experienced User
Yes, mostly applicable to wireless connected RBS out in a line from each other for using the wireless backhaul.
- mabwriterApr 20, 2020Aspirant
Thanks. Do you know if there is a performance difference in the different topologies? For instance is one of Star, Daisy-Chain, or Switch wired backhaul preferable, or will I get the same performance/stability?
The Netgear website shows how to do all three, but I can't find pros/cons for each type.
- CrimpOnApr 20, 2020Guru - Experienced User
mabwriter wrote:Thanks. Do you know if there is a performance difference in the different topologies? For instance is one of Star, Daisy-Chain, or Switch wired backhaul preferable, or will I get the same performance/stability?
Wired in a star best all the way. Every situation is different, so Netgear shows examples.
