zhtway
Jan 01, 2021Aspirant
Daisy Chaining two LAN ports of RBS20 to other network wired device
There are two LAN ports at the back of RBS 20. Satellite unit. one port is connected to the switch. Can I connect another port to the network Printer? If so, will that RBS20 be working as pass thr...
- Jan 02, 2021
I have an RBS20 hardwired to a switch then on to the RBR50. The switch is on one side of the wall and the RBS20 is on the other side of the wall. I didn't feel like running another cable through the wall to connect it to my TV so I connected the TV to the RBS20. The IP is assigned from the router and is visible from the GUI and also on the Orbi app.
zhtway
Jan 02, 2021Aspirant
Thanks for the reply.
This Orbi RBS20 is connected to the RBR20 (router) on one port (through the switch).
RBS20 (Satellite Unit) has two LAN ports.
So one is used up (to the router above).
From the remaining port, I want to connect to the other device (printer) near that Orbi Satellite.
Will that device be visible in my network?
Devices are at my other location. So I couldn't test it yet.
I think it will be.
Thanks
DeanB1452
Jan 02, 2021Apprentice
- zhtwayJan 02, 2021Aspirant
Thanks. I guess RBS20 works as a pass through switch like in most VoIP Phones.
But I couldn't find the explaination in anywhere. :-)
