Pfredd
Jul 28, 2018Guide
Daisy Chaining with a CBK40?
It appears that the RBK series of ORBI routers support Daisy Chaining of satelites.
Why is this feature not available on the CBK40?
- Aug 01, 2018
Here is Netgear Support's response to my case regarding the lack of a Satelite Daisy Chaining option:
We have been informed that the Daisy chain feature is enabled by default and is not a configurable option in GUI. Thank you for letting us know about this. Also, we will forward this to the appropriate team and send a feature request to add this function as a configurable option in the future FW like we have for all other Orbi products.
Pfredd
Jul 28, 2018Guide
OOPS, Meant CBR40
- vkdeltaJul 31, 2018NETGEAR Employee Retired
Daisy chain is supported. It is enabled by default.
It does not have option to disable it but the device will auto-adjust between DaisyChain vs Star based on strength of the backhaul links.
- FURRYe38Aug 01, 2018Guru - Experienced User
Thanks for this information. Will keep this in mind.
- PfreddAug 01, 2018Guide
