Pfredd
Jul 28, 2018Guide
Daisy Chaining with a CBK40?
It appears that the RBK series of ORBI routers support Daisy Chaining of satelites.
Why is this feature not available on the CBK40?
- Aug 01, 2018
Here is Netgear Support's response to my case regarding the lack of a Satelite Daisy Chaining option:
We have been informed that the Daisy chain feature is enabled by default and is not a configurable option in GUI. Thank you for letting us know about this. Also, we will forward this to the appropriate team and send a feature request to add this function as a configurable option in the future FW like we have for all other Orbi products.
vkdelta
Jul 31, 2018NETGEAR Employee Retired
Daisy chain is supported. It is enabled by default.
It does not have option to disable it but the device will auto-adjust between DaisyChain vs Star based on strength of the backhaul links.
Aug 01, 2018Guru - Experienced User
Thanks for this information. Will keep this in mind.
