thescinema
Mar 16, 2021Guide
Daylight Savings Time, NTP, DNS Issues
 Something is going on with Orbi routers and NTP/DNS.     Since the time change, many users are reporting issues with their DNS failing since the time change:  https://www.reddit.com/r/orbi/comments/m...
Mar 16, 2021Guru - Experienced User
Users will need to make contact with NG support and let them know what your seeing. For the most part if all troubleshooting has been exhausted, NG needs to be contacted.
Some users have had some luck in setting NTP with other servers, Factory resets or downgrade FW as last resort. Other may have not seen this issue as well.
You can reach out to forum moderators as well:
