thescinema
Mar 16, 2021Guide
Daylight Savings Time, NTP, DNS Issues
Something is going on with Orbi routers and NTP/DNS. Since the time change, many users are reporting issues with their DNS failing since the time change: https://www.reddit.com/r/orbi/comments/m...
Blanca_O
Mar 17, 2021NETGEAR Employee Retired
Hi Orbi Community,
The issue has been forwarded already to engineers.
If you are willing to work on the issue, please send me a private message by clicking on this link and I will PM you requesting for more information. We appreciate your help working on this issue.
Blanca
Community Team
- thescinemaMar 17, 2021Guide
Blanca_O wrote:Hi Orbi Community,
Blanca
Community TeamPM Sent. Really do not want to do a factory reset. I know I can just restore from a backup but I am concerned about the satellites not being re-added after the restore. If I can confirm the satellites will work without re-pairing them with the main router, then I'd be OK with a factory reset as a test. Ideally I would like to just have this fixed, though.
- FURRYe38Mar 17, 2021Guru - Experienced User
The RBS will re-sync to the RBR if you use same SSID name and PW if you reset the RBR.
- thescinemaMar 20, 2021Guide
FURRYe38 wrote:The RBS will re-sync to the RBR if you use same SSID name and PW if you reset the RBR.
I use three satellites and only one of them re-synced with the RBR after the factory reset & restore the config backup. Had to factory reset and re-add the other two. Kind of a pain since one of them was in the ceiling of our detached garage.
- vajimMar 18, 2021Master
Blanca
Great...please let the NG moderators help with your problem
