thescinema
Mar 16, 2021Guide
Daylight Savings Time, NTP, DNS Issues
Something is going on with Orbi routers and NTP/DNS. Since the time change, many users are reporting issues with their DNS failing since the time change: https://www.reddit.com/r/orbi/comments/m...
Blanca_O
Mar 17, 2021NETGEAR Employee Retired
Hi Orbi Community,
The issue has been forwarded already to engineers.
If you are willing to work on the issue, please send me a private message by clicking on this link and I will PM you requesting for more information. We appreciate your help working on this issue.
Blanca
Community Team
thescinema
Mar 17, 2021Guide
Blanca_O wrote:Hi Orbi Community,
Blanca
Community Team
PM Sent. Really do not want to do a factory reset. I know I can just restore from a backup but I am concerned about the satellites not being re-added after the restore. If I can confirm the satellites will work without re-pairing them with the main router, then I'd be OK with a factory reset as a test. Ideally I would like to just have this fixed, though.
- FURRYe38Mar 17, 2021Guru - Experienced User
The RBS will re-sync to the RBR if you use same SSID name and PW if you reset the RBR.
- thescinemaMar 20, 2021Guide
FURRYe38 wrote:The RBS will re-sync to the RBR if you use same SSID name and PW if you reset the RBR.
I use three satellites and only one of them re-synced with the RBR after the factory reset & restore the config backup. Had to factory reset and re-add the other two. Kind of a pain since one of them was in the ceiling of our detached garage.
- FURRYe38Mar 20, 2021Guru - Experienced User
One thing to try before a reset, try a power cycle for the one in the garage. Power OFF for 15 seconds then back on to see if it will reconnect on it's own. Sometimes thats all thats needed on the RBS.
- vajimMar 18, 2021Master
Blanca
Community TeamPM Sent. Really do not want to do a factory reset. I know I can just restore from a backup but I am concerned about the satellites not being re-added after the restore. If I can confirm the satellites will work without re-pairing them with the main router, then I'd be OK with a factory reset as a test. Ideally I would like to just have this fixed, though.
Great...please let the NG moderators help with your problem
