thescinema
Mar 16, 2021Guide
Daylight Savings Time, NTP, DNS Issues
Something is going on with Orbi routers and NTP/DNS. Since the time change, many users are reporting issues with their DNS failing since the time change: https://www.reddit.com/r/orbi/comments/m...
thescinema
Mar 17, 2021Guide
Blanca_O wrote:Hi Orbi Community,
The issue has been forwarded already to engineers.
If you are willing to work on the issue, please send me a private message by clicking on this link and I will PM you requesting for more information. We appreciate your help working on this issue.
Blanca
Community Team
PM Sent. Really do not want to do a factory reset. I know I can just restore from a backup but I am concerned about the satellites not being re-added after the restore. If I can confirm the satellites will work without re-pairing them with the main router, then I'd be OK with a factory reset as a test. Ideally I would like to just have this fixed, though.
Mar 17, 2021Guru - Experienced User
The RBS will re-sync to the RBR if you use same SSID name and PW if you reset the RBR.
