thescinema
Mar 16, 2021Guide
Daylight Savings Time, NTP, DNS Issues
Something is going on with Orbi routers and NTP/DNS. Since the time change, many users are reporting issues with their DNS failing since the time change: https://www.reddit.com/r/orbi/comments/m...
jeffnielson
Jun 16, 2021Aspirant
Any updates on when this will come out?
I still have issues.
- CrimpOnJun 16, 2021Guru - Experienced User
jeffnielson wrote:Any updates on when this will come out?
The Traffic Meter/Daylight Saving Time issue was resolved in April when the Traffic Meter 'turned over' to the next month.
If you are still having issues, creating a new post describing the situation in detail will be more effective than adding to this thread.
That TM/DST issue made the Orbi basically unusable and people were desperate.
