abernathy's avatar
abernathy
DC current requirement
I have an RBR20 router and two RBS20 sats. I am also a ham radio operator, so adding stuff with switch mode power supplies, which are RF noisy, is not a good plan. I am going to use 12VDC linear powe...
  • FURRYe38's avatar
    Others have said that NG uses better quality power supplies than other Mfr so this is something to try as well. There is some specs that some devices need so using the default power supply would be recommended.
    I haven't seen any issues with these power supplies an my radio equipment. :smileywink:
    Good Luck.
