gregvi
Aug 19, 2024Aspirant
DDNS setting not working with No-IP. They've changed their domain name.
I’m trying to figure out a way to file a bug for a RBR50 running V2.7.5.4 firmware. The Orbi DDNS settings in the firmware still has www.No-IP.com listed in the pull-down and it no longer works...
- Aug 19, 2024
The Orbi AC series is EoL. So most likely won't see a FW update.
Something you can try is Voxel's 3rd party FW:
Aug 19, 2024Guru - Experienced User
gregvi
I was afraid that was going to be the answer. Too bad for such a simple change but I totally understand.
If products didn't have EOL then Microsoft would still be supporting and patching Windows95. Obviously, not feasible.
Looks like I will be updating my DNS record manually.
Thanks!
