gregvi
Aug 19, 2024Aspirant
DDNS setting not working with No-IP. They've changed their domain name.
I’m trying to figure out a way to file a bug for a RBR50 running V2.7.5.4 firmware. The Orbi DDNS settings in the firmware still has www.No-IP.com listed in the pull-down and it no longer works...
- Aug 19, 2024
The Orbi AC series is EoL. So most likely won't see a FW update.
Something you can try is Voxel's 3rd party FW:
CrimpOn
Aug 19, 2024Guru - Experienced User
gregvi
First, it appears that No-IP.com resolves to an IP address using nslookup:
Non-authoritative answer:
Name: No-IP.com Address: 158.247.7.199
Second, My Orbi RBR50 updated the DDNS records at No-IP.com on July 27: The first entry reported 'failure', followed immediately by 'successful'.
(and there has been no entry in the Orbi log since that time - either 'success' or 'failure')
[Dynamic DNS] host name 172.249.112.### registeration successful, Saturday, July 27, 2024 12:20:28 [Dynamic DNS] host name 172.249.112.### registeration failure, Saturday, July 27, 2024 12:20:28Since my public IP does not change often, I am not certain how often the Orbi updates No-IP.com
I agree with FURRYe38 Netgear is not likely to release new firmware for the RBR50. It remains unclear to me how much of an issue this poses for users. The RBR50 can update two other DDNS services. And, it remains unconfirmed that this change results in No-IP.com not updating DDNS entries that have already been established.
