RYELEX
Feb 25, 2019Initiate
DDOS Attacks causing disconnecting internet connection
My internet connection keeps on disconnecting and after going through the logs, there are DDOS attacks that is causing this. I had contacted my ISP to get new IP, that didn't work. I got the latest O...
almhuss
May 10, 2019Aspirant
Problem may be in the response of the router to ping requests. Go to Advanced>WAN Settings and be sure the “Respond to Ping requests” is unchecked (disabled). If the router actually needs to respond to Ping (or ACK, SYN, or other DoS attacks), it will bury itself and you will get the magenta ring.
Unfortunately, if you are using OpenVPN through the firmware, enabling OpenVPN will automatically enable (check the box) for Respond to Ping requests. You cannot have one without the other. This is a major bug in the firmware. Netgear has known of this for 2 years, and there is no solution on the horizon.
ekhalil
May 10, 2019Master
I overcame this limitation (enabling VPN will automatically enable Respond to Ping) by doing the following telnet command (this does not impact VPN, it will continue working and the router will stop responding to pings):
root@RBR50:/# config get wan_endis_rspToPing
You will get the default which is 1 (means Orbi should respond to WAN ping requests)
root@RBR50:/# config set wan_endis_rspToPing=0
root@RBR50:/# config commit
