hotshotnz
Jul 23, 2018Aspirant
Dead orbi after firmware update
Updated Orbi firmware (not sure what release it was as Orbi is now dead), started to update - progress bar showing progress, then PC disconnected as ethernet ports reset. Orbi powered on - no lights,...
Jul 23, 2018Guru - Experienced User
Try this:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034
If any of this fails to recover the router, you'll need to contact NG support:
https://www.netgear.com/support/contact.aspx
hotshotnz
Aug 02, 2018Aspirant
No, dead.
Netgear say that they can't issue RMA because no replacements in stock. Contacted 4 times in past 12 days; ring back after 48 hours is the reply.
Highly unsatisfactory; going to go back to the retailer and replace through them as NG service is a joke
- FURRYe38Aug 03, 2018Guru - Experienced User
Retail return is valid as well. Good Luck.
- AnonymousAug 03, 2018
another victory for manual updates....
