BillYoung's avatar
BillYoung
Luminary
Oct 01, 2018
Default Gateway is 10.0.0.1; how do I access my modem now?
To anyone who is concerned:   Under my current network setup, I am unable to access my modem setup pages.  My Default Gateway is 10.0.0.1, which is the IP address of my Orbi.  If I attempt to acc...
  • FURRYe38's avatar
    Oct 01, 2018
    When modem/router combos are placed in full bridge mode, then some modem Mfr may not offer modem web page access anymore to the UI since it's DHCP services and such are disabled in bridge mode, there no need to access the modem for any reason. You will need to refer to the modems Mfr to see what is supported in bridge mode. In most cases, you won't need to access the modem in bridge mode which is fine.
