BillYoung
Oct 01, 2018Luminary
Default Gateway is 10.0.0.1; how do I access my modem now?
To anyone who is concerned:
Under my current network setup, I am unable to access my modem setup pages. My Default Gateway is 10.0.0.1, which is the IP address of my Orbi. If I attempt to acc...
- Oct 01, 2018
When modem/router combos are placed in full bridge mode, then some modem Mfr may not offer modem web page access anymore to the UI since it's DHCP services and such are disabled in bridge mode, there no need to access the modem for any reason. You will need to refer to the modems Mfr to see what is supported in bridge mode. In most cases, you won't need to access the modem in bridge mode which is fine.
randomousity
Other than what FURRYe38 said, I had a cable modem (I don't remember whether it was a Motorola one, or a Netgear one) whose configuration page was at 192.168.100.1. You could give that a try. Or google your modem and see whether it's even accessible in bridge mode, and, if so, how. But I've also experienced that some modems, when in bridge mode, are, effectively, invisible on the network, at least from the LAN side. I have a dual cable modem/router from my ISP, and they offer wifi for an additional monthly charge. If you don't pay, the modem gets provisioned in bridge mode, and there's no way to connect to the modem's config page that I can figure out. If I power-cycle it with the coax disconnected, I can get into the modem settings, but, of course, there's no internet access. Connecting the coax requires a power cycle to get it to register, at which point there's internet, but not config access anymore. Catch-22.
But, beyond that, what is it you hope to gain by accessing the modem config page? In my experience, there are few, if any, user-configurable settings. If it's super important to you for some reason, and if the modem being in bridge mode isn't set by your ISP, you ought to be able reset it and then choose to put it in router mode instead, and then set the Orbi in access point mode I suppose.
